They did not take enought time in the product design on the 680 MM frame and in my opinion its a shotty job. They have 2.5MM x 28MM screws that attach the non-moving arms to the frame and the 2 outer screws that go into the landing gear part is about 2MM too short. At this point why you tighten them down the force of pulling the frame together will only pull the threads out of the landing gear leg. You have to have as much thread length going into the hole as you have diameter thread. And these outer screws have less than half that length.
