flysolo
I have done a lot of changes and major repairs to my 550 dfc and now I can't get the esc to work. I'm learning at everything so it's probably something I did, not a faulty component I think.
When connecting the battery there is nothing, no sounds at all. There seems to be power because the 3gx works and it gets the power from the esc right?
Someone got some tips what to check? Are the beeps coming from the motor? You think bad connection between esc and motor maybe?
I did stick the amp sensor between the battery and the esc and that would be the first place to check but since I get power to the 3gx that can't be the problem?
