Here is the scenario. Flew my FBL Trex 500 (IKON)and hovered fine the day before except for a little tail wag so I inspected the heli and found the movement of the tail a little sticky which gave me an “ah, ha” moment. Assembled (everything now smooth. Went to fly it today and found, at first the tail a little awkward and with out warning the heli spun 360 deg. I shut it down and check all the connections and smooth operation. Ran it with out the head and everything “seemed” ok. Reassembled and tried again. Same thing happened. NOTE: the direction is the same as the last input on the stick.
I am thinking I need to verify all the settings in the IKON unless someone here has any other ideas.
