A Goblin 500 and a Gaui X5 uses some where around 84mm tail blade. My Gaui X3 uses some where around 62/68mm tail blade. My question is; Can I use a 82mm tail blade on my Gaui X3 instead of the 62/68mm? My main blade size on the X3 is 362mm. I don't think the tail and main blades will hit. I've heard if you can go with a bigger tail blade, that is recommended, you will have better response/reaction with your heli. Just wanting to know.
