Paulster2
I am El Taco!
I received my new metal gear servos last night and got them installed for the most part. There was two minor things which I had to deal with. First, the arms are a lot shorter than the ones I had on my 450. Tony said this would be alright, so no big deal. Second, the body of the servo is a bit skinnier (screw hole to screw hole). I ended up mounting one screw in the hole, with the second hole to the outside of the body in a notch at the end of the servo. This, believe it or not, still allows the servo to be mounted quite well. There is no movement out of it at all. These servos seem to be pretty sturdy. I'll keep you guys posted as to how they work out. Tony sure likes the ones he has installed. The PN on these is: Servo_MG90S on hobbypartz.com
