I'm trying to level the swash.
I turn on the Tx then the heli. After the heli initializes, I put the collective at 50%. I then put the wire tie at the arm for the elevator. Turn the rotor to the next arm and it doesn't touch (right side as viewed from the rear). I then go into the screen you see to adjust sub trim to get it to where it needs to be. After that, the left side arm is too high. This is the point I can't figure out how to get the arm down without affecting the right servo.
