holtneil
Hi guys I just want tell you what a strange time my goblin had , it all started with the scorpion motor bearing failing and the motor grinding to a stop the motor was really hot , so I posted the motor off to my best mate smoggy , he rebuilt it and tested it then posted it back , I refitted it and took it up for test , It was not good it looked like the rotor disc was still but the heli was doing a belly dance under it so I landed no matter what head speed used it didn't make any difference and battery was running out of power fast,I normally get 8 mins flight time now It was less than 6
A call To smoggy tech support , we both could not decided if the magnets were cooked , but we both decided it's worth a calibration of the YGE esc so I charged the flight pack to 4 volts a cell and did the calibration
It worked heli is back to normal no more belly dance , the strange thing is why did the motor failing make the ESC forget it's throttle setting
