I set up my swash for STD flight. I had the throttle all the way to the bottom when I set up the sub trims. The problem is that the blade pitch is way off as it's range is 0 to ~24 degrees. Swash collective pitch can't compensate to get it down to 0 - 9 degrees.
Does the swash set up always need the throttle at mid stick? I'm just starting out and don't want any negative pitch for now.
__________________
__________________
