Harford
I thought I would start a new thread to focus on the Spirit Pro set up - well at least the questions I have about this process.
To re-cap, this is about installing a Spirit Pro on a Trex 600 (electric) using a DX9 and two Spektrum DSMX satellites.
My first question concerns the Swash settings in the Tx. The manual says select the swash type for yr model which in my case is CCPM 120. I have done this in the swash type menu but the manual goes on to say any swash mixing in the Tx must be switched off (configured to H1 single servo type). The swash mix settings in my Tx are currently set ay +60% for Ail, Ele and Pit. These must be default values as I did not enter them. What do I do here please in order to comply with the instruction to switch off swash mixing ? (set them to 0% ?). I have gone through the set up process using the wizard with them set like this so will I need to redo some/all of the set up ?
Next question is cyclic ring tuning. I am not sure what I need to do here so any guidance would be appreciated. The manual also refers to setting the Aileron/Elevator maximum cyclic pitch range which I am not sure about. I have set the collective pitch range (+/- 10 degrees) and the cyclic pitch at 6 degrees.
Third question is about the best way to set the rudder gain. Can you possibly give my a step by step process to follow using the DX9 Tx.
Your help with this would be much appreciated.
