No, that's nonsense. The only 'issue' with the AR8000 is that it doesnt support single line output like some of the latest receivers do, so on a flybarless heli you would have to wire it conventionally with a wire for each channel (no big deal). I've personally used an AR8000 on a heli as have many others without issue.
So what problem are you having with the throttle?
Has your AR8000 been in a crash ? I had one a couple of years ago that worked fine until an unfortunate incident with the ground, everything still worked after that except for the throttle.
Broke my heart to throw it in the bin, I have another on the same age that is still going strong.
A few things to check:
Is the throttle plug the correct way around?
Are you sure that you calibrated the throttle correctly? Did you get the arming tones at the end of the calibration process?
Is there any movement at all from the motor (twitching or pulsing)?
Photos of your wiring may be helpful
I'm no expert, but on mine the ESC goes to the throttle. The bind port is left open.
Jim
