Yeah Smoggie, some of this has to do with personal preference as far as the set up is concerned. I’m not computer illiterate. I come from the days before windows, when there was just a C prompt on a black screen and do 99.o% of any of my needed computer repairs. So it was, at least in the beginning, exciting to get on to it and set up the fbl but over time it became cumbersome, mainly when it got to setting up, or should I say, trying to set up the bailout feature. Now I found I was in a new area, an area that I didn’t understand, talk of - gyro settings etc. Didn’t make any sense to me. Now it became complicated and since I’m a very analytical person if I can’t understand how and why something works the way it does its write up becomes jargon. So despite having fbls that have bailout they weren’t functional so it just became much easier to set my birds up with something like the AR7200. The one other fbl I have is the Bavarian Demon that is in the Bell 47GII. And despite the fact that it’s operating fine the bailout is not set up on that one either.
As far as a BEC the only bird I have that has one is the Bell 47, and that’s only because there wasn’t room on the bird to install it unless I stuck it outside somewhere. All my other birds, including the 600L has a separate primary battery. This allows me to work on the cyclic system without worrying about the main motor or blades. It also allows me to yes, test the fbl and servos to make sure all is functioning normally before I connect the main motor. That’s how I found out there was no response of the servos on my 600L the first time it failed to connect with the TX.
It is strange that you have rock solid performance from your spirit pros yet my two failed with the same symptom characteristics despite having different set ups. It’s too bad we’re so far apart as it sounds like you have a considerable amount to offer. If we were able to have worked on them together the root cause would most likely have been found. The only thing, to me, that is evident is the what but not the why. Thanks for your input Smoggie!
