Quad Spectrum Dx8
Ellis
Hi I have a spectrum DX8 that I am running a blade 350 QX with does anyone know how to set the return home switch to the gear switch ?
You should be able to do this by going into the Channel Assign Menu. Make sure your Tx is on the model you want and turn it off. Hold the roller and power it on. This will put you into the System Setup menu. Scroll down to Channel Assign. I don't know if you are running the G1 or G2, but if running the G2, I think switch D is what you want. Once in Channel Assign scroll to Next in the lower right. Find the channel RTH is on now, and move it to the switch you want.
