Daniel Migneault
I have a Blade 450 3D, i tried to use the same setup from a DX-6i on my DX-9 Black edition, i guess it's not strait forward, any help would be appreciated, thanks!
had to reverse elevator , rudder.What part of the setup doesn't seem right?
Saw that but because you most of the time use a Trex and not a Blade, that confuse me a little, maybe i should not?I have a few videos on setting up the DX9. Have you watched them. There is a link below to the article page where all the DX9 articles are. The Basic Helicopter Setup article would probably be the most helpful in this case though.
DX9 | Rc-Help Forum
I saw some diffences between Dx-6i, Dx-7 and Dx-8 concerning the swash mix? can you explain me that, thanks.Pretty much every single CCPM helicopter is setup the same. You start with your new model in your Tx, once you have that, you move on to centering the servos and setting those servo arms to exactly 90º to the links they are connected to. This will give equal travel in each direction. While still at mid stick, you verify 0º pitch, again at mid stick (50%) and if you are not at 0º, adjust the linkages on the head, not the swash to servo links to achieve 0º at mid stick. From there, go full positive and full negative and check the pitch. If you have more positive than negative then your swash is too high. If you have more negative than positive, then your swash is too low and you need to adjust your servo to swash links accordingly. Then, go to mid stick and do it all over again checking for 0º pitch, then full positive and full negative.
It can be a long process, but it is pretty much the same on all helicopters. Especially those made today. Back in teh day with weird collective rods going through the main shaft, those are a little different, but the blade 450 3d is very similar to the Align kits.
If you do need further help, we are here to assist. Just let us know what you are needing help with and we will jump on the issue.
