380/420 Setting Up Walkera 36 Heli
J T
hi, I have a walkera 36 heli. and I am using a dx6i trx. the pitch lever moves up at spool up to lift off, but the pitch moves down when the aileron is pushed to the right. have tried several things to correct this effect. what am I doing wrong?
Can you post a video on what the helicopter is doing? That will help us diagnose it much easier.
Check to make sure the transmitter is on single servo the FBL unit does the mixing
thanks a million, that fixed my problem. these units came with 72 mzh trx and rx . I am changing everything to 2.4 ghz. do you have a 36 or just have had the same thing happen to you. again thanks.
