Thought I would start a newe thread for this rather tha muck up previous ones.
I am in the early days of learning to fly my Align Trex 450 Pro. I recently have been playing with total blade angle trying to get it more settled vertically. Head speed has been constant through this at about 3200 rpm (idle up) and I initially took total blade angle down to 10-degrees positive and 10 degrees negative. Aside from not curing the vertical instability I developed a flutter-like sound as I began to apply collective to lift off.
I took blade angle to 12-degrees positive and 12-degrees negative and vertical stability felt better and the short flutter sound when collective was applied seemed shorter but was still there.
Just this morning IK took blade angle to 14-degrees positive and 14 degrees negative and it feels much better in terms of holding an altitude and the flutter sound on collective application is gone.
I have heard lots of theroies on the best total blade angle but so far 12.5 to 14 degrees positive and the same negative seems to be the most popular. I guess I am going to stick with the 14 degrees if there is no good reason not to.
