If I'm understanding this correctly, to set the Governor Mode on an ESC for a helicopter, you need to take the number of poles and divide that number by two. I'm looking a motor for a 450 heli and, in the specs for this motor, it says "Pole Count: 5". Is that common? Most motors that I've looked at have an even number of poles.
Update
Ok, I think I have that wrong. It's when I'm tring to calculate the head speed, I would need to know the pole count and the gear rate of the main drive gear vs the pinion. It looks like actually "setting the governor mode" is rather straight forward. However, I'm still perplexed that the motor I have been looking at has an odd number of poles. Even more so odd, I looked at another motor and it says it has a pole count of 4.5. How can you have 4.5 poles???
Update
