Servos Servo issue
bigone5500
The servos I got from amazon have squared plugs. The Rx I have has two of the corners beveled. I guess I can simply sand off the corners with a sanding block and make them work right?
Yes you can. Just make sure your wires are where they need to be. red should always be in the center, then just align the negative and signal with the Rx.
bigone5500
Thanks. After I posted I went ahead and tried sanding a couple of them the fit is tight but they work.
Thanks.
Just an FYI, the Airtronics above is the old style. They changed it to center positive back in 04 or something, maybe earlier.
