EDF Servo Arms
Falcon1954
I am looking for heavy duty servo arms for the Turnigy TGY_S712G thin wing servo. Does anyone know where I can find the heavy duty aluminum arms. The plastic ones will not work. If not what else might fit this servo. Turnigy does not tell me what the spline count is.
Thanks
Richard
Dubro makes some heavy duty arms that I use on everything that requires strength. I run these on my 50" Edge 540 and I'm also using them on my 58" F4U Corsair. Never had a single issue. What are you going to use these on that you are wanting aluminum?
Falcon1954
These will be used with ball link setup. The plane is a 13 - 15 lb. Gulfstream 2048 ed fG500 jet made by hobbyking. I am using the Turnigy thin wing servos for the flaps as the wing is not deep enough for anything else. Looking for arms that are small diam shaft. Not sure what the spline count is. Thanks
