ESC scorpion esc
Well I got all the connectors soldered on. Connected all the components to the power system and attempted to set the throttle range.That did not go as planned. After watching a video I finally got it set. My only problem is that the throttle needs to be reversed in the tx. I hope this is not an issue.
By the weekend I hope to have the servos set, mounted and the swash level. As far as the esc goes, it needs to be mounted outside the air frame. It is longer and slightly wider than the dynum. Other differences is that the rx cable is shorter and the ir rx gives just enough cable to run the wires to the back. I hope to have a short video by the end of the weekend.
