I'm sure by now you have read that I was having some issues with the SG3. This is supposed to be the phone of all phones. Out of the numerous people I have talked to and asked, they told me to go with this one over the iPhone 5. Everything about this phone was supposed to be better. So I headed to Best Buy and i picked it up.
One of the first things I noticed is just how much lighter this phone is compared to the iPhone 4 that I also have. That plus the expandable memory and replaceable battery were other reasons I decided to get this phone. When we got home I started playing with it and I could not find anything wrong with it. 4G LTE speeds, better signal than the IP4, doesn't lose signal when you palm the outside case like the IP4 and the screen is MUCH better. So far so good.
However when I got to work I started noticing issues. Not with the phone, but with the network. The phone, being an LTE phone, kept looking for an LTE signal. Well way out here where I work, there is only 4G, not 4G LTE. So every time it would look for the LTE signal, it would reset the signal and fall back to 4G. In this process it would lose signal about every 10 minutes. When you are trying to work on the internet, this is an issue.
I called tech support knowing that I would be talking to someone that couldn't pull a coin out of a coin return. Yeah, just dialing the number was pissing me off lmao. So I get ahold of this guy and he says this is a wifi issue. At this time, I didn't know it was a network issue, so I agreed. Gave him the number to call me on the base line and send an update to the phone. We disconnected and I went back to testing. And guess what, same issue.
So I started reading up on the net trying to figure this issue out. I found nothing. So the next day, I called tech support back. They said they had another update they could send to the phone. I said fine, we did the same thing as above and I started testing. Same issue. No waiting this time, I called them back. this time, I didn't hide being pissed off lol. I do remember telling the guy, after he started arguing with me that he wasn't intelligent enough to pull his own head out of his ass, then he hung up on me. Yeah, that was fun lol. But that was the last straw, I decided to take the phone back this friday.
When I came to work tonight I saw that I had a response to my blog and it was good ole Matt saying he had found some links on what could fix this. I searched for hours and didn't see these posts. the first is an app, and it does nothing but show you what your phone is doing at that time. The second link, so far, has worked out great. Unfortunately with this, I will lose LTE speeds at the house, but who cared, I'm on wifi there anyway.
All of the below, if you do this to your phone, is done at your own risk. Rc-Help.com nor I am responsible if/when you brick your phone. With that said, this is stupid simple and you can get it, I think lol.
All I had to do to fix this issue is get rid of the LTE signal and disable it, was first remove the back cover to expose the sim card. Leave the battery in and push down on the sim card to release it then pull it up. It won't come out because of the battery, but I didn't have to remove this. After a bit, you will get a warning and it will force you to reboot your phone. After the reboot, you just type into the keypad *#2263# and it will automatically come up with a very basic menu with different options.
In that menu you will see a list of different things and after ONE of them you will see (*). The one with that (*) symbol is the one that is selected. Default is Automatic. You want to select the one that says something like "WCDMA All" DO NOT CLICK INTO THE NEXT MENU'S AND CHANGE THE BAND!
After you do that, reboot the phone and it will stay on Edge (2g), 3g and 4g only. This will also allow voice calls and such but will not look for the LTE signal. So far, I have had this done to my phone for about 4 hours and it's working great, I have not lost signal yet. so far, that is the only issue I have found with this phone. But unlike apple, there IS a hack to figure it out and bypass it. With Apple, you are just stuck with what they give you.
So I may not be taking this phone back after all. There is so much that I can do with this thing. I have lost a lot of sleep just because I like playing with this thing lmao. Pisses the wife off lmao.
So if you have the SG3, let me know what you think about it.
