holtneil
Hi Guys I hope one of you Goblin guys can tell me if this is right , in the manual it tells you to pre-load the tail belt tensioner by 270 degs , 270 degs is a bit strange I pre-loaded it by 360 degs and locked it with a carbon rod to the outside of the frame to hold it there I then pulled back on the tail to tension the belt and locked the tail with the belt tight , I then let the belt tensioner go so its now at about 270 degs and is holding the belt nicely the tail adjustment is at half its adjustable travel , Is this the right way to set up as I dont want to over tension the belt , the Idler is sitting level with the side of the frame as the manual said
