600 Reversed Pitch Curve
Brad330l
Hi guys, might be a bit of a newby question but I do need to know if a reversed pitch curve is ok to use to get everything going in the right direction. I have trailing edge arms on the blades and this seems like the only way I can get around not beibng reversed some where either being cyclic or pitch. Trex 600 with 3GX and DX9.
The flybarless head is a converted fly-barred one with Mikado conversion kit.
So "yes" or "NO!!"
Cheers
No that would be a bad idea.
With trailing grip arms the collective travel can be reversed in other ways. With the 3GX it's done in the swash mixing menu in the Tx and/or servo reversing
Definitely no! If you have a swash setting of Normal or 1 servo 90, then just reverse the pitch servo as Geena stated. If you are running a 120 3 servo swash in your tx, then find your swashplate menu, swash mix menu, whatever it is called, and there should be 3 parameters in there, aileron, elevator and pitch. ail and ele do just as you would think, pitch is your collective. You will just take this from a positive number to a negative. Or vise versa.
