EDF Retract sequencer question
fran11784
Not sure about this. Putting together this Viper and the gear door sequencer has a battery port and a signal port. They say to use 7.4 volts to the battery and they give you a male to male extension for the the receiver signal. Im thinking the battery (center wire) on the signal wire I should remove right? Cant have two power wires Im thinking. Very vague instructions.
Perhaps a link to the product page would be in order... there are several Viper's out there and having info about which one you are talking about is recommended.
fran11784
I've tried, cant find anything. Only thing I can tell is its a Electron retract system. But its a over 10 year old model and I don't think they make it anymore. I'm pretty sure you use only ground and signal, that's what is marked on the controller. I tried to email Electron, their still in business... See if they respond. Thanks
