Ok so Derek the landing gear is made from 3/32 piano wire following this pattern. The red lines show the alteration that allow the strap to fit over. So follow the red lines.
You just bend the wire to match the pattern and you can make it taller or shorter as needed, I'll try to do a video.
Then figure out approx. where the back of the LG will set, make a small hole for the wire in the fuse and snake it thru, I hot glued popsicle sticks to be a backer for the wire against the horizontal fuse plate and then as you can see from the pictures, I secured the wire with plastic LG straps and servo screws into the popsicle sticks and added the tires.
EyeStation, The motor mount is actually the one from Dereks bi-plane pattern, which sadly is no longer in my fleet due to an over applying of the earth brakes
I just used his pattern and modified the cut out area of the Edges nose to fit it in I use 3/16" hobby ply-wood, You can sort of see by the picture I added some down thrust.
Hope that helps guys
Flew it today video coming soon!
