Okay everyone, this has been a long awaited plane, and it's here. We are still working on it, but I have it where people can test it and give responses.
A little background. This plane was designed by Derek. He drew out the plans on some foamboard and took some pictures of them. I then took those pictures and created the plans that you will see when you click on the link. I will let Derek do some more explaining on the plane and setup, but this will get you all to the point of testing it if you so wish. And I hope you do.
The plans are still in the beta stage, and they are no where complete. I have marked some servo locations on the plans, but that is about it. There is no CoG location, but according to Derek, it's just shy of 50% chord on the top wing. Or right in the middle of the upper wing support coming off the fuse.
So here are the plans. Post up suggestions as you find them. We are all ears. And most importantly, we are VERY HAPPY to have another plane for you guys to fly!
View attachment rchbipebeta1.pdf
Here is a list of electronics used on Derek's Bipe
1100kv brushless motor
Turnigy D2836/8 1100KV Brushless Outrunner Motor
30amp ESC (because the motor was rated at 18amps)
TURNIGY Plush 30amp Speed Controller (US Warehouse)
4 - 9 gram servos work very well
HXT900 9g / 1.6kg / .12sec Micro Servo (US Warehouse)
3S 1300mah lipo (a 1000mah lipo was tested but the 1300mah lipo helped with cg)
Turnigy 1300mAh 3S 30C Lipo Pack (US Warehouse)
A Spektrum AR400 4-channel receiver and a "Y" Servo Harness was also used.
