Projects RC-Help Trainer?
APBurner
Where is the original thread for the trainer. V1, V2 and V3. I have the plans from many years ago but don't remember much about the plane. I have tried searxhing but get many hundreds of hits when I search for the plane. A link would be very helpful. Thanks
Steve
Here is the playlist for the V1 build guide. I unfortunately never did v2 or v3 on video. And you can access the files by clicking on "Store" at the top of the screen.
APBurner
When building this plane do you peel the paper off. Also is there a place with finished pictures of each to see the difference.
It depends on the surface. If it is a critical surface that the glue must hold to as much as possible, then yes, I will peel the paper back, but only in that spot. The paper in both areas helps make the plane stronger. So I leave as much on it as possible.
