There are actually two motors listed on that page, Tony! As stated above, I'm using the 1000kv motor. On my trainer, I have two pieces of 1/8" plywood as a firewall and the motor attached to the plywood. Something I was thinking was cutting two more squares, to match the ones on the plane, and mounting that on the plane as well. Not only will it add a bit more weight to the front, but it will also put the motor a bit further away from the CG. I'm just trying to "make due" until I can get a bigger motor. I do have a 10x5 prop and I'm stoked about trying it if/when the flying weather comes back. It got down right cold and windy these last few days. 2.5" of rain, 45mph wind gusts, and then it snowed a bit last night. ugh!!!
