General rc ELECTRIC PLANE
falcan
Finally got my electric EZ trainer 1200mm wing span 930KV motor from hobby king
painted the fuse red (water base spray paint can ) makes it easier to see on cloudy days too much white ,
White and blue on rc models dont like it ( white =clouds- blue = sky colour) can be hard to see at times
Have done the mod's =wing dowels - hot glue the plastic screw mounts on wing and landing mount- longer spar carbon fibre bar in wing 18 inches long past the servos in the wing ,
bigger motor from a 880 kv to 930kv - glued in tail and screwed in place - put a sleeve on rudder wire stop flexing - epoxy glue on front wheel horn on top make it stronger - they break on hard landings- hot glued the servos in the fuse - glued the battery hatch leg mine came loose -
