General Raptor 30 Dx6i
Gary Anderson
Hi guys I pretty new to heli always had cars, I have a raptor 30 with dx6i, when I bought it 2nd hand with a propo, the propo was not the greatest so bought the dx6i then realised had to buy a new ar7000 now in the manual it only seems to give 3d settings so am looking for settings for my dx6i for begginer also is setting for Swash 1 servo or ccpm 120 cheers
buel williams
hi gary and wellcome to helis. on my 6i I set my curves at 0 25 50 75 100. put your other settings in norm flight mode. swash at 1 servo at 90 degrees
Matt
The swash setting in the dx6i is 1 servo (normal)
for the 3 flight modes the pitch curves go like this:
N: 46 48 50 75 100
Ui1: 0 25 50 75 100
Ui2: 0 25 50 75 100
the throttle curve is this:
N: 0 75 75 75 75
Ui1: 85 85 85 85 85
Ui2: 100 100 100 100 100
Let me know if this helps.
Gary Anderson
N: 46 48 50 75 100
Ui1: 0 25 50 75 100
Ui2: 0 25 50 75 100
N: 0 75 75 75 75
Ui1: 85 85 85 85 85
Cheers have got more help here in last 2 days than Facebook last 2 months thanks guys in dx6i settings are L234h also you have ui1 is that stunt mode ui2 hold mode cheers
Matt
Iu1: is idle up 1
IU2: is idle up 2
there is a “flying style” setting on the ar7200bx, set that to beginner mode. It adds a lot of expo and dual rate so the heli is more easier to fly.
Matt
the ccpm in the dx6i should be 120
the pitch and throttle curves are the same
add a lot of expo 35% on aileron, elevator
add 15% expo on rudder
check out this video
Gary Anderson
Ahh ok will set it up tommoz or next day an take some pics of settings I did try start with settings I found as heli hasn’t ran for few months fires up great still but had to pinch fuel line as main rotor wanted to spin, I used trim setting to lower carb but looks like need to reset the rod
Matt
I’m no help with a nitro heli. I’ve only dealt with electric helis. But everything is the same except for the motor. There are a couple videos on the setup. There is an article section of this website that has a lot of how to videos. There are a bunch of videos on the YouTube rc-help.com channel.
Its based on the fbl unit not the radio or anything else. If you were flying a standard flybar helicopter then yes 120 is the right choice unless its a newer raptor. Newer raptors were set to 130° swash.
Now if your flying an fbl unit like ikon or brain, ar7200 , bear neo then your radio is set to single servo. This turns off the radio mixing feature and allows the fbl to do the mixing.
Since you are flying a raptor you might want to double check the swash and make sure its a 90° swash.
