claytonbakerjr
Hello all.
As you may have seen in the introduction area I am in the process of putting together a quad.
After debating about my power distribution board connections I have decided that I want to
redirect wires and such to make it look cleaner. In turn hooking all leads together and
getting rid of the PDB.
Now if you looked at the pics you will see I have sandwiched the ESC's between the bottom
and middle plates.
I would like to keep it that way however I need to question HEAT.
In a sandwiched config would the ESC's possibly get too hot and burn out due to such heat?
I have seen others with the same type of setup but no mention of failures in light of heat.
Thanks in advance
and middle plates.
Thanks in advance
