im looking at getting a plane kit shortly and the kit comes with two set ups for the rudder, pull pull and push pull what aare the pros and cons of each setup?
I use pull/pull and have done for 20 years except when I use a single pushrod. It is a great method and when set right slop free. Good luck.
Updated this to pull/pull getting old pull/pull def the best of the two systems. Apologies for any confusion.
pull/pull is what most 3D planes will use. It takes all of the slop out of the rudder. Little harder to setup, but works great. the push/pull is great for ease of setup, but you can get some flutter at high speeds.
