coolgabsi
Super Mod & DEAL KING!
Alright
its been months and the plane was staring at me.. And I was day dreaming of flying it all this time.. Finally got the guts to start working on my first real Balsa built plane. The good part is that it was given to me built and used / stored / hangar rashed, so all I had to do was fix couple things.. First things I fixed was remove the hinge of all control surfaces, clean them, and reinstall them with cloth hinges. That was a fun discovery --> cloth hinges.. esp for a helicopter man.. heehee.. anywaz.. after that. I got the engine installed after a 3 hours of work on it. had to cut out some wood cowling and spinner and what not.. have the engine securely seated in there... Fixed the landing gear... now plane stands on its LG with confidence.
Now is the time before I out cosmetics like cowling and stuff on to test this frame see is it really worth it... its a great planes kit .40 size for 2 stroke.. or .60 4 stroke.
I put a 10x6 prop on it for now. Is that right prop size? should I go bigger? I am not sure . should I go with 11x6 or 11x5 or something.. I am not good at this stuff.. I need y'alls help.. Then engine I am using on it is OS 46 FX. with a straight pitts muffler. Engine mounted inverted (not that it maks a difference) .
Plane is gonna be a bit heavy as I can see.. I havent installed the battery in it yet.. planning on going with a Life 2 cell battery, I have a 5000mah one lying around.. its big and a bit heavy but I know it'll not need charging for a LOOOOONG while... So this is primarily a questions about prop. but anything in here looks off to you.. please let me know.. I'll fix it..
Also.. my fuel tubing is kinda tight in the back of the engine.. and it is touching the backplate screws or backplate outer in general.. is that acceptable ? should I be worried?
Thanks y'all
Thanks y'all
