This print is for caps for XT90 batteries to show their charge state. Green is charged, Red is discharged and Yellow is storage charge. Simple. But, I had things to do and did not want to print these 3 times, and I did not want to have hundreds and hundreds of filament changes to print 6 little items, so I utilized a "Print By Object" feature in Bambu Studio under Others > Special Mode > Print Sequence. In there you have By Layer and By Object. By layer, it will print each layer and change colors 3 times per layer. This print is 70 layers high. But, because these are smaller pieces, I could group the colors together and set them to print by Object and it will print in the sequence of colors you select on the build sheet (just click settings on your sheet you are working on). This is very handy to simplify those multi color prints that the objects are the same color, you just want to click print only one time!
