Tasajara
Well have not done a scratch build plane in a while so got to looking for something different.
I have never flew off of water so I found the plans to a Polaris Sea Plane thought I would give it a try.
Using Blue FanFold I have laying around.
Balsa for all control surfaces.
Epoxy and Foam Safe CA for my glues.
Use Mirco Ballones mixed into the epoxy to fill
gaps , makes the epoxy lighter and easier to sand.
That is why the glue joints may seem white.
Ultra Coat covering, it is low temp covering.
use it with care and you can cover foam pretty easy.
Here are a few of my build pics so far..
Little Dry Fit to get an idea what it may look like
The rounded edges will be what hits the water, Fuse is the float for this plane.
Trying to make it smooth as possible.
