Re: Pimped my heli,airbrushed by myself.trex700E DFC,assault 700 airframe.everything
Q, tony,I'm in the setup on the AR7200BX,I've whatch your videos on the setup but I'm stuck on L,I'm binding at the top and bottom of swashplate.backed it off with the rudder stick but the light goes to red.then I have no binding.but it's say you have to be blue led.i was at blue at first when I went into L.i went back to G to try and sort it by my links,can not shorten them any more what I have.its seems to me there is to much throw on elivater when I go full stick and it binds at the top.i back it off and it turns red then it's fine.then at the bottom I had to back off alieron that turned red.then everything works fine.what do you suggest?cheers chris.i can try and post a video of it,if that helps.
