I bought it this way. I removed the RX already but like the ESC where its at. The thing gets pretty warm and where its at it will get a breeze from the blades. Right now I have a serious tail oscillation that I haven't figured out yet.I would mount the ESC in a different location as well. If that is one of the later versions, and judging by the DFC head it is, you should be able to mount it under the battery tray. Much cleaner look. And if you are running the DX8, and there is a 3GX in the frame, you can get rid of that Rx too.
Your making me want the 250 again, you need to stop lmao. I love those little heli's even though they are a pain sometimes.
You might be onto something program which output channel to aux2? I will try this at lunch time.If you using just Sat Rx, make sure to set output channel in the gyro menu to aux 2 ( NOT gear). Check the programming in ESC, making sure it is programed to start in SOFT START mode ( and NOT the SOFT START + GOVERNOR mode). For DX8, a gyro gain value of +40 is a good place to start.
The gain on the pots shouldn't change. Are you talking about the ail/ele gyro gains? Or are you talking about endpoints? Because gains and the binding have nothing to do with each other. The gains for the ail/ele are set in the computer program (so you can see the output) but are physically adjusted on top of the gyro with the two pots.
If you are having binding issues, then you need to go into your swash menu and lower those numbers until you get the amount of pitch you want. about 8º on cyclic, and I would not go over 11º on collective. Hope this makes sense.
I do the cyclic pitch in DIR. and you are the second person that has had the gyro give off a LOT of pitch after you exit DIR. I'm going to have to test this on the RCH Heli to see if it does the same thing.
Something is not quite right with the 3GX I lost control and took a nose dive into the dirt. Broke feathering shaft and bent main shaft. So it's gonna be a while I need to sort out the 3GX issues.Sweet. So when can we expect a video of the little guy in the air?
Yea that's what happened to this one. I had control an then it's as if it was trying to correct and giving it to much aileron. It was hard as heck to fly. I got it as close to the ground as I could then hit throttle hold. I have a 3GX in my 450 and that one flies just fine so I'm not sure what I did wrong yet.Another 3GX claims another victim. I almost had a crash this weekend with the 600 trying to put it into the air the first time. The swash was all over the place because the gyro was trying to correct something that wasn't even happening.
