  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
General Paint For Epo Foam
Discussion in 'Airplanes' started by Capn Pete, Jun 25, 2018.
< Installing A Propeller | Cleaning Carb Gunk >
  1. Capn Pete
    Capn Pete Active Member
    Oct 17, 2017
    126
    1
    28
    Gender:
    Male
    N. Carollina
    What type of paint is safe to use on EPO foam? Would you paint with a brush or spray?
  2. Tony
    Feb 21, 2011
    36,671
    1,419
    113
    Any water or oil based paint will be safe. Avoid anything with Lacquer thinner in it. And test a piece of the foam if using oil based thinned with Mineral Spirits.
    And I would use an airbrush. They give the best results. But you can also use an aerosol can or a brush as well, it just doesn't look at good IMO. And be careful how much you put down, it does add a pretty good amount of weight.
  3. Capn Pete
    Oct 17, 2017
    126
    1
    28
    Gender:
    Male
    N. Carollina
    thanks, Tony. I was kinda wondering about the lacquer thing. Good point about the weight factor too. I'm mainly just thinking of some highlights.
  4. Tony
    Feb 21, 2011
    36,671
    1,419
    113
    IMO, water based paints would definitely be your best bet.
Share This Page
