  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Prop P-51 Mustang?
Discussion in 'Airplanes' started by fireman7234, May 15, 2017.
< 2204 motor that isn't running up to speed | Decent receiver >
  1. fireman7234
    fireman7234 Member
    Blog Posts:
    0
    Jan 14, 2017
    34
    0
    6
    Gender:
    Male
    Occupation:
    Electrician/Firefighter
    North Carolina
    I was giving this plane it came with a brushed motor I want to put a brushless motor in it. Plane has a 30" wing span and a 8.5x6 prop im new to the hobby need some recommendations on what motor to go with? Not looking for anything to fast.
  2. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,170
    1,409
    113
    In all honesty, I would try to match the prop size to a motor with about the same dimensions as the one that you have on there now. It is a lot of work to find, but unless you know the size of the stock motor, this is the best way. If you have the size of the stock motor though, it will make the search much faster.
    Palehorse01 likes this.
  3. rdsok
    rdsok Well-Known Member
    Blog Posts:
    0
    Sep 11, 2011
    1,585
    60
    48
    Norman, Ok USA
    You'd also need to know what the specs on the gear box are... so you could find the right kV to look for as a starting point.
  4. Admiral
    Admiral Well-Known Member
    Blog Posts:
    0
    Mar 2, 2014
    1,988
    123
    73
    Gender:
    Male
    Occupation:
    Information Technology (Retired)
    Brisbane, Australia
    It looks very similar in design and build as a 30" foam Corsair that I had and did a brushless upgrade on, I went too big and had a rocket ship, it flew, but torque rolled like hell and was nose heavy, I used the motor and propeller from the 1100mm Durafly Corsair, was great fun though.
    If I were doing it again I would probably use Motor: 2825-1950kv Brushless outrunner motor ESC: 20A High-Spec 3~4S and start with an 850 mAh 3S battery that way if it didn't have enough power I could upgrade it by going to a 4S battery, I would also use a 5.5x 4.5 propeller.
    The Corsair with too much power on too small an oval.
  5. Oldensly
    Oldensly Member
    Blog Posts:
    0
    Dec 28, 2016
    52
    6
    8
    Gender:
    Male
    Occupation:
    RETARED
    West Virginia
    Looks to me as if it kept you very busy while it was flying! Ah but the end is sad. Recoup, regroup and forge ahead!
Share This Page
