Oops!
cml001
So I don't have video... I don't know what u call this maneuver if in fact it ha a name... Fly across the field from right to left and pull vertical pointing the noise to the sky.. Right at stall do a 360 piro.. As u start to fall aileron roll and pull out back across the field backwards and inverted... As it passes in front of u, piro 90 degrees so the heli is nose in, still inverted and traveling back across field.. At this point more neg pitch to start a sideways, inverted loop... Then dumb thumb! I made the loop but must have pitched wrong cause I drove her staight in the ground! Done this a lot on sim and serveral times at the field... Just dumb dumb'd it today... Can't believe the blades made it! Had this heli a year.... 3rd crash... Pretty good record I guess... As I said no video... But here is the aftermath!
Sucks.... But... She will live to fight another day!
treff
Thats pretty bad luck but I thing in the background of your pix says it all
GOO Gone. I think that sums it up nicely. Has they say, rebuild and get back on
that horse........................................................Could have been a lot worse.
