Kettenhund
Greetings! I have an Ofna monster pirate in buckets. I will most likely never put this truck together again as there are some broken parts, and what parts you can find are expensive. I was looking into 1/8 scale diffs for my E Maxx, as I am running it with a castle motor and esc on 6s. I know there are cases out there to put 1/8 diffs in the Maxx format. My question is - does anyone know if the ofna planetary style diffs will work in that application? The output stubs are not swappable to the e-Revo style, as the initial planetary on each side is part of the output shaft. That means I would be stuck using the drive cups for the pirate. Anyone know if this is a viable option?
