Power Supply's New Power Supply Set Up Question?
FlyNmonkeyNutz
Hey Fellas, I am in the process of building a power supply like those sweet ones in some other threads and I have a question. I would like to use a cool toggle switch to power up the two PS units when I use them so I can just leave it plugged up on my bench all the time, is there a good way (Safe way) to do this? If so can you help me out with some tips on the wiring to the toggle?
Below is the pinout for this PSU. You will take pin 4, 6 and 10 and put them on one side of the switch, then run pin 8 to the other side. Once you flip the switch closed, it will power on the PSU. Hope this helps.
FlyNmonkeyNutz
New PS updates ....added sweet toggles , high voltage wrap (just cause it looks awesome), modded Harbor Freight case and added a 3" cooling fan soldered to the AC line coming in .....more too come !
Couple more shots of the wrap
pvolcko
I might opt to put them both on one switch, so you don't accidentally shut off one mid charge and put your charger into freak out mode, perhaps even cook something. Pretty cool otherwise. :)
