FBL Gyro Neuron Flybarless DX8 transmitter setup
RoofusHeli
Does anyone out there have any appearance with the first setup for the DX8 when programming the Neuron flybarless unit? Info on the Neuron seems to be very thin on the ground.
Thanks RoofusHeli
I have never even heard of that gyro, but more than likely you are going to run either 1 servo 90º (or Normal depending on what version DX8 you have) or 3 servo 120º on your swash type. From there, it should just be a matter of setting up the gyro, getting your blade pitches correct, dialing in the cyclic and tail gains and getting some DR/Expo in there.
based off what I found it looks like the radio will be set to 1 servo 90 degree. Then in the fbl unit you will select swash type.
