If you can't find info on it, then I would just set it up manually. Set it at mid stick, adjust the swash to 0 pitch. Then check full positive and negative. If they are the same, you are set. If you have more positive than negative, then your swash is too high. If you have more negative than positive then your swash is too low. This would mean your servo arms are not perfectly 90 to the linkages. Adjust as needed until you get 0 at mid stick and equal (within a half degree) positive and negative pitch.
