Spektrum Moved the trainer switch on my DX8
Dirk
I moved the trainer switch on my TX to the gear position. It is so much easier to get to. I use the trainer switch for the bailout on my Ikon.
Now the switch is right by my finger so no more stretching or missing the switch during an "Oh CRAP!!!" moment.
Right on. However, because this is a momentary push button switch, and bail-out usually would require you to have the switch on until you are sure you have control, I would put the gear switch back there and use that switch. Wait, on a heli that switch does nothing... Okay, I would get a good switch like the others and use that. Just don't forget to turn it off when you turn your Tx off after binding lmao.
Dirk
Hi Tony,
The bailout switch is pressed for maybe half a second only. That's how fast the Ikon flips the heli to an upright position! :bolt:
