Raising 1 tooth on the pinion is like dropping 3 teeth on the main gear. So raising a single tooth on a pinion is pretty substantial. If your motor, ESC and battery are cool after a flight, you can go up a tooth. Just watch teh temp. If it's getting too hot, then go back down. If you are needing more head speed, it's worth a shot.
