Motors Motor oil
Hey everyone, after flying five flight on my heli, i add couple of drops of 3&1 oil to my motor. I was wondering if i can use the same oil to lube my main shaft bearing block bearings and tail shaft bearings or should i use some sort of other lubricants on the bearings. What about white lithium grease for the main and tail shaft? any suggestion will be helpful. Thanks!
You can but for a motor I would suggest scorpion motor oil. Its designed for high speed applications. As for oil on the other bearings, I use tri-flow. Its like an oil version of wd40.
Based on the research that I did, on this very topic earlier this year, I use the exact same stuff that Matthias just suggested. The Scorpion oil for the motor and tri flo for the other bearings.
Fortunately, neither the Scorpion Oil nor the Tri-Flow are very expensive but they are definitely a "must-have".
I found where to buy Tri-Flow @ HeliDirect but which Tri-flow? Where can i buy Scorpion oil?
BTW, scorpion oil should only be used on the motor. Just an FYI.
