Motors Motor help
Pkhill27
Ok guys so I have a crawler and I ran 2 brushed motors parallel to a xl5 and they run opposite directions. Any help?
There is no one answer since it will depend on the type of brushed motors you have. Some brushed motors can go both forward and reverse... but some are only meant to spin in one direction. If these motors can be reversed, just reverse the wires to one of the motors. If they aren't made to operate in both directions though, you could ruin one motor or it may just not operate as efficiently and will run slower.
The following is a general way to find out which it may be but it's a crude method... so your results may vary...
If you can see the brushes and commutator ... look at the brushes and make certain they are perfectly perpendicular ( 90° ) and centered completely on the brushes.... If so then hook up a single battery to one and listen, do the same for the second motor to hear if it sounds like it's spinning the same speed. If you have a tachometer that you can hook up, it will tell you more accurately the speeds than just listening to it.
If they are the exact same motor and in the same direction (pinion forward for example), then they should spin the same direction. Can you post a picture of your wiring? Some motors 'can' be run in reverse, but usually lose power since you are reversing the timing thus retarding the motor.
