FBL Gyro Mini Ikon Pitch Travel Setup Challenge
USAF_Ret
I am trying to install a Mini Ikon FBL into my Trex 250 and cannot seem to get the negative pitch adjustment to -100%. The best I seem to be able to get with the max travel adjustment on the radio is -48%.
I can get all of the other travel settings set to there respective +/ - 100% just not the negative pitch.
I am using a DX18.
I have reset the FBL to factor settings and rebooted the application, radio, and FBL multiple times with the same result.
Thoughts?
Paul
Make sure you are using a linear throttle and pitch curve when setting up the ikon.
