  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
FBL Gyro Microbeast J
Discussion in 'Helicopters' started by Matt, Apr 16, 2019.
< Min/max Pitch? | Banggood >
  1. Matt
    Matt Member
    Blog Posts:
    0
    Mar 27, 2018
    269
    2
    18
    Gender:
    Male
    Milford, MA
    What if I don’t get a blue light on Setup Menu item J? Should I fly the heli or should I work to get a blue light on Setup Menu item J? Blue light is a “green light” that the geometry of the head is good for a fbl heli.. people with experience with AR7210BX or similar fbl control should know the answer to this..
  2. D.O.G.
    D.O.G. I Support Rc-Help! Rc-Help Supporter Goblin 380 Supporter
    Blog Posts:
    0
    Jul 9, 2013
    2,654
    96
    58
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    Hey there Matt. I have the AR7200 BX. Alot of individuals aren't able to get the blue light special. I was able to do so on mine but if you can get the 6 degrees and get close as you can to the blue light, it should be fine. If i'm correct, Tony and other weren't able to get the blue light on and they still completed the setup and flew their helis. Don't quote me but Tony will know better then I.
  3. Matt
    Matt Member
    Blog Posts:
    0
    Mar 27, 2018
    269
    2
    18
    Gender:
    Male
    Milford, MA
    I think that’s what it says in the manual.. the blue light is secondary.. it says to get 6 degrees of pitch on the cyclic and if there is a blue light.. if not then just know the geometry is not optimal.. and fly knowing the geometry is not optimal..
  4. D.O.G.
    Blog Posts:
    0
    Jul 9, 2013
    2,654
    96
    58
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    Here's Tonys video and go to 13:42 and he talks about the blue light .
Share This Page
