I have a scorpion commander v-700 ESC. It is capable of 2-4S at 11 amps max output. I would like to build a micro plane with $tree foam board if possible. I don't think I will be able to use foam board for this.
Any high wing design or wing design will work. Parts for this can be cheap I.e. hobbyking. I also have two mg90s servos lying around too.
Here is the esc that I have:
Scorpion Commander 12V 11A ESC LBEC (V2) - Scorpion Power System
Possible motors:
Turnigy Park300 Brushless Outrunner 1600kv
Turnigy Park300 Brushless Outrunner 1080kv
Possible props:
7x3.5 Propellers (5Pcs/Bag)
GWS EP Propeller (DD-9050 229x127mm) orange (6pcs/set)
I would like to do a pusher if possible.
Possible motors:
Possible props:
